Ga door naar hoofdinhoud
SuperSonic Matrix Mid SC-999 Headphone Jack Replacement
Wat je nodig hebt
  1. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: stap 3, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement, Headphone Jack: stap 4, afbeelding 1 van 1
    • Locate the headphone jack on the device.
  5. SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: stap 5, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Desolder the 5 soldered connections (marked in red) that connect the headphone jack to the device.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot, so be mindful in your handling.
Conclusie
Harris Dagha
866 Reputatie
7 handleidingen geschreven
Dr Shaverz boyz Lid van Dr Shaverz boyz
Community
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 228
