Ga door naar hoofdinhoud
SuperSonic Matrix Mid SC-999 FM Antenna Replacement
Wat je nodig hebt
  1. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 2, afbeelding 1 van 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 3, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 3, afbeelding 2 van 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: stap 4, afbeelding 1 van 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: stap 4, afbeelding 2 van 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, Battery: stap 4, afbeelding 3 van 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 5, afbeelding 1 van 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 5, afbeelding 2 van 3 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 5, afbeelding 3 van 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: stap 6, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement, FM Antenna: stap 6, afbeelding 2 van 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  7. SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 7, afbeelding 1 van 2 SuperSonic Matrix Mid SC-999 FM Antenna Replacement: stap 7, afbeelding 2 van 2
    • Desolder the FM antenna from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Harris Dagha
866 Reputatie
7 handleidingen geschreven
Dr Shaverz boyz Lid van Dr Shaverz boyz
Community
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 201
