Ga door naar hoofdinhoud
Steelseries Rival 700 Gaming Mouse Nameplate Replacement
Wat je nodig hebt
  1. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the mouse from your computer: stap 1, afbeelding 1 van 2 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the mouse from your computer: stap 1, afbeelding 2 van 2
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: stap 2, afbeelding 1 van 3 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: stap 2, afbeelding 2 van 3 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: stap 2, afbeelding 3 van 3
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate removal: stap 3, afbeelding 1 van 2 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate removal: stap 3, afbeelding 2 van 2
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate printing: stap 4, afbeelding 1 van 1
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vincent Monteil
6.975 Reputatie
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 2,250
