Ga door naar hoofdinhoud
SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement
Wat je nodig hebt
  1. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: stap 1, afbeelding 1 van 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: stap 1, afbeelding 2 van 3 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement, GameDAC Potentiometer: stap 1, afbeelding 3 van 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 2, afbeelding 1 van 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 2, afbeelding 2 van 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 3, afbeelding 1 van 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 3, afbeelding 2 van 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 4, afbeelding 1 van 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 4, afbeelding 2 van 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 6, afbeelding 1 van 2 SteelSeries Arctis Pro Plus GameDAC Potentiometer Replacement: stap 6, afbeelding 2 van 2
    • Desolder the seven potentiometer pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Hoe moet je (de-)solderen?.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Avinash Vadlamudi
451 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G1, White Winter 2019 Lid van Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Leden
21 handleidingen geschreven
3 opmerkingen
Hi there,
do you know what type of potentiometer is needed?
Greetings
Chris
Christian Humann - Antwoord
I would like to know too. Cause it failed for me as well!!
Antonis Lazarakis - Antwoord
Can I replace the Oled Screen with 2,42 inch arduino oled display that also have 24pin flex?
Muso!27 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 79
Altijd: 4,615
