Inleiding
Use this guide to replace the left trigger (L2) in your Steam Deck OLED.
Although the procedure is nearly identical, follow this guide to replace the right trigger (R2).
Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Wat je nodig hebt
Power down your Steam Deck and unplug any cables.
Gereedschap gebruikt in deze stap:FixMat$36.95
Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
Slide your pick along the edge of the handle to release the clips securing it to the front shell.
Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
Remove the back cover.
Grip the battery cable pull tab, located to the left of the battery.
Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
During disassembly, skip the next four steps.
Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
Reconnect the interconnect cable ZIF connector.
Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
Place the flat end of a spudger onto the inside edge of the trigger's left clip.
Use your fingers to push the trigger toward the left as you wedge the spudger between the clip and the peg.
Use your spudger to pivot the trigger clip out, away, and up from the peg to unlatch it.
Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Één andere persoon heeft deze handleiding voltooid.
