Ga door naar hoofdinhoud
Steam Deck OLED Back Cover Replacement
Wat je nodig hebt
  1. Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 1 van 3 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 2 van 3 Steam Deck OLED Back Cover Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 3 van 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Back Cover Replacement, Remove the back cover screws: stap 2, afbeelding 1 van 2 Steam Deck OLED Back Cover Replacement, Remove the back cover screws: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Back Cover Replacement, Unclip a handle: stap 3, afbeelding 1 van 3 Steam Deck OLED Back Cover Replacement, Unclip a handle: stap 3, afbeelding 2 van 3 Steam Deck OLED Back Cover Replacement, Unclip a handle: stap 3, afbeelding 3 van 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: stap 4, afbeelding 1 van 3 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: stap 4, afbeelding 2 van 3 Steam Deck OLED Back Cover Replacement, Unclip the top and bottom edges: stap 4, afbeelding 3 van 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Back Cover Replacement, Remove the back cover: stap 5, afbeelding 1 van 3 Steam Deck OLED Back Cover Replacement, Remove the back cover: stap 5, afbeelding 2 van 3 Steam Deck OLED Back Cover Replacement, Remove the back cover: stap 5, afbeelding 3 van 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Clay Eickemeyer
68.062 Reputatie
453 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.525 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 88
Afgelopen 30 dagen: 396
Altijd: 2,558
