Ga door naar hoofdinhoud
Sprout Channel Cubby Speaker Replacement
Wat je nodig hebt
    1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: stap 1, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: stap 1, afbeelding 2 van 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Vraag FixBot
      Voeg opmerking toe
    1. Sprout Channel Cubby Speaker Replacement, Speaker: stap 2, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement, Speaker: stap 2, afbeelding 2 van 2
      • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
      Vraag FixBot
      Voeg opmerking toe
    2. Sprout Channel Cubby Speaker Replacement: stap 3, afbeelding 1 van 2 Sprout Channel Cubby Speaker Replacement: stap 3, afbeelding 2 van 2
      • Remove black tape.
      • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
      • Replace the speaker.
      • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jasen biggins
741 Reputatie
5 handleidingen geschreven
USF Tampa, Team 14-101, Meier Fall 2015 Lid van USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Leden
12 handleidingen geschreven
2Gids Commentaar
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Antwoord Deel
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 1,577
