Inleiding
This guide will require the use of a Phillips head screwdriver. The ribbon connector is usually the reason the device will need this replacement.
Wat je nodig hebt
Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
Use the opening tool or a fingernail to release the ZIF connector.
Disconnect the camera ribbon cable.
Remove the camera.
