Ga door naar hoofdinhoud
Spin Master Boxer Robot Speaker Replacement
Wat je nodig hebt
  1. Spin Master Boxer Robot Speaker Replacement, Robot Screen: stap 1, afbeelding 1 van 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Speaker Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Speaker Replacement: stap 4, afbeelding 1 van 2 Spin Master Boxer Robot Speaker Replacement: stap 4, afbeelding 2 van 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Speaker Replacement, Robot Speaker: stap 6, afbeelding 1 van 2 Spin Master Boxer Robot Speaker Replacement, Robot Speaker: stap 6, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, unscrew the two 3mm screws connecting the black speaker cover to the top panel.
  7. Spin Master Boxer Robot Speaker Replacement: stap 7, afbeelding 1 van 1
    • Remove the speaker cover and you will be left looking at the speaker.
    • The speaker is soldered onto the top panel so additional measures must be taken to completely remove it. See Hoe moet je (de-)solderen?
Conclusie
Lauren Roide
739 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G1, Maness Spring 2019 Lid van Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 994
