Ga door naar hoofdinhoud
SoundBot SB571 Battery Replacement
Wat je nodig hebt
    1. SoundBot SB571 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Before disassembling the speaker, make sure it is powered off.
      • Place the speaker on a flat surface.
      • Take your blue plastic opening tool and remove the outside cover.
      Vraag FixBot
      Voeg opmerking toe
    2. SoundBot SB571 Battery Replacement: stap 2, afbeelding 1 van 1
      • Reorient the speaker so the black panel is facing up.
      • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
      • Now remove the plate.
      Vraag FixBot
      Voeg opmerking toe
    3. SoundBot SB571 Battery Replacement: stap 3, afbeelding 1 van 1
      • Reorient the speaker so the bottom is facing up.
      • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
      • Now open the plate.
      Vraag FixBot
      Voeg opmerking toe
    4. SoundBot SB571 Battery Replacement: stap 4, afbeelding 1 van 2 SoundBot SB571 Battery Replacement: stap 4, afbeelding 2 van 2
      • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
      Vraag FixBot
      Voeg opmerking toe
    5. SoundBot SB571 Battery Replacement: stap 5, afbeelding 1 van 2 SoundBot SB571 Battery Replacement: stap 5, afbeelding 2 van 2
      • Disconnect the battery wires from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    6. SoundBot SB571 Battery Replacement: stap 6, afbeelding 1 van 3 SoundBot SB571 Battery Replacement: stap 6, afbeelding 2 van 3 SoundBot SB571 Battery Replacement: stap 6, afbeelding 3 van 3
      • Reorient the speaker so the back side is facing up.
      • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
      • Loop the battery wires through the opening in the back plate.
      • The battery and it's connective wires have been completely removed from the speaker.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
Yana
672 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-50, Cagle Spring 2016 Lid van USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Leden
18 handleidingen geschreven
9Gids Commentaar
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - Antwoord Deel
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - Antwoord Deel
They don't sell batteries!!
international.loop - Antwoord Deel
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 9,628
