Ga door naar hoofdinhoud
Sophix TAB-730g Battery Replacement
Wat je nodig hebt
  1. Sophix TAB-730g Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: stap 2, afbeelding 1 van 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: stap 3, afbeelding 1 van 1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
Conclusie
JT Hiquet
333 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Harley Fall 2016 Lid van IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 Leden
6 handleidingen geschreven
Één opmerking
[|how do you know if the problem is or is not the battery?]
Don Taylor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 368
