Inleiding
This is a pre-requisite list of steps that will act as a placeholder for all other applicable guides pertaining to the Sony a7.
Wat je nodig hebt
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using the blunt tweezers, remove the blue ribbon cable.
9 andere personen hebben deze handleiding voltooid.
