Ga door naar hoofdinhoud
Sony a7 LCD Screen Replacement
Wat je nodig hebt
  1. Sony a7 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
    • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
  2. Sony a7 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the switch over to the right side to open the battery door.
  3. Sony a7 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Depress the blue lever to allow the battery to pop out slightly.
  4. Sony a7 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the camera.
    • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
  5. Sony a7 LCD Screen Replacement, Rear Disassembly: stap 5, afbeelding 1 van 1
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
  6. Sony a7 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Sony a7 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Sony a7 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
  7. Sony a7 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
  8. Sony a7 LCD Screen Replacement: stap 8, afbeelding 1 van 2 Sony a7 LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the four M 1.5x2mm screws.
  9. Sony a7 LCD Screen Replacement: stap 9, afbeelding 1 van 3 Sony a7 LCD Screen Replacement: stap 9, afbeelding 2 van 3 Sony a7 LCD Screen Replacement: stap 9, afbeelding 3 van 3
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
  10. Sony a7 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
  11. Sony a7 LCD Screen Replacement: stap 11, afbeelding 1 van 2 Sony a7 LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
  12. Sony a7 LCD Screen Replacement: stap 12, afbeelding 1 van 3 Sony a7 LCD Screen Replacement: stap 12, afbeelding 2 van 3 Sony a7 LCD Screen Replacement: stap 12, afbeelding 3 van 3
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
  13. Sony a7 LCD Screen Replacement: stap 13, afbeelding 1 van 1
    • Lift the metal plate and LCD screen away from the camera body.
  14. Sony a7 LCD Screen Replacement: stap 14, afbeelding 1 van 1
    • Detach the amber ribbon cable from the motherboard.
  15. Sony a7 LCD Screen Replacement, LCD Screen: stap 15, afbeelding 1 van 2 Sony a7 LCD Screen Replacement, LCD Screen: stap 15, afbeelding 2 van 2
    • Remove four M1.5x2mm screws with a PH00 Phillips screwdriver.
  16. Sony a7 LCD Screen Replacement: stap 16, afbeelding 1 van 2 Sony a7 LCD Screen Replacement: stap 16, afbeelding 2 van 2
    • Using the iFixit opening tools, pry the plastic casing off the back of the LCD screen.
    • It may be difficult to remove the backing from the LCD, so it does require a fair amount of cautious pressure.
  17. Sony a7 LCD Screen Replacement: stap 17, afbeelding 1 van 1
    • Seperate LCD screen from its metal backing.
  18. Sony a7 LCD Screen Replacement: stap 18, afbeelding 1 van 1
    • Remove the ribbon cable that connects the LCD screen to the camera by using the iFixit opening tools.
    • In order to successfully remove the ribbon cable, it will be necessary to lift up on the connector.
Conclusie
5 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
this isn’t finished
Max Faulhaber - Antwoord Deel
Hello,
If by “isn’t finished” you mean that the instructions do not contain the steps to put the camera back together, this was done in the hope that the user would follow the steps in a reverse order to put the camera back in one piece.
Best.
Jeffrey Coleman - Deel
completely-incomplete tutorial in 4 steps
I hope you never made a plane like this
Gue - Antwoord Deel
Hello there,
Thank you for your constructive comment. The criteria we needed to meet for this project was to provide instruction on iFixit guides for how to remove various parts on the device. We were being evaluated on the content pertaining to our writing and not the technical depth of the guide. Furthermore, we did not have a vested interest in replacing the screen nor did we have another screen to replace it with. In your rush to make a rude comment, you might have missed the end of the guide where it states that in order to reassemble you must follow the steps we provided in the reverse order. Reverse means doing something in the opposite direction.
Regards.
Thanks for the guide.
Tyler Steck - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 83
Afgelopen 30 dagen: 340
Altijd: 22,781
