Ga door naar hoofdinhoud
Sony Xperia Z5 Rear Glass Replacement
Wat je nodig hebt
  1. Sony Xperia Z5 Rear Glass Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Sony Xperia Z5 Rear Glass Replacement: stap 2, afbeelding 1 van 2 Sony Xperia Z5 Rear Glass Replacement: stap 2, afbeelding 2 van 2
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • Pull up the suction handle to generate a gap.
    • Insert an opening pick into the gap to further separate the rear glass from the phone assembly.
    • The adhesive of the Xperia Z5 is fairly weak and it is possible to remove the rear glass without the use of an opening pick. In case you‘re having trouble you can have a peek at the opening procedure of the Xperia Z4.
  3. Sony Xperia Z5 Rear Glass Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z5 Rear Glass Replacement: stap 3, afbeelding 2 van 2
    • Carefully lift and remove the rear glass.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Conclusie
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape after cleaning the according areas with isopropyl alcohol (>90%).
Dominik Schnabelrauch
211.821 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.085 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 983
