Ga door naar hoofdinhoud
Sony Xperia Z2 Logic Board Replacement
Wat je nodig hebt
Video overzicht
  1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: stap 1, afbeelding 1 van 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: stap 1, afbeelding 2 van 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: stap 1, afbeelding 3 van 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Xperia Z2 Logic Board Replacement: stap 2, afbeelding 1 van 3 Sony Xperia Z2 Logic Board Replacement: stap 2, afbeelding 2 van 3 Sony Xperia Z2 Logic Board Replacement: stap 2, afbeelding 3 van 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Xperia Z2 Logic Board Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z2 Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Xperia Z2 Logic Board Replacement, Battery: stap 4, afbeelding 1 van 3 Sony Xperia Z2 Logic Board Replacement, Battery: stap 4, afbeelding 2 van 3 Sony Xperia Z2 Logic Board Replacement, Battery: stap 4, afbeelding 3 van 3
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: stap 5, afbeelding 1 van 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: stap 5, afbeelding 2 van 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: stap 5, afbeelding 3 van 3
    • Unscrew the screw and remove the Wi-Fi Antenna.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Xperia Z2 Logic Board Replacement, Logic Board: stap 6, afbeelding 1 van 2 Sony Xperia Z2 Logic Board Replacement, Logic Board: stap 6, afbeelding 2 van 2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
    Vraag FixBot
    Voeg opmerking toe
  7. Sony Xperia Z2 Logic Board Replacement: stap 7, afbeelding 1 van 3 Sony Xperia Z2 Logic Board Replacement: stap 7, afbeelding 2 van 3 Sony Xperia Z2 Logic Board Replacement: stap 7, afbeelding 3 van 3
    Vraag FixBot
    Voeg opmerking toe
Conclusie
19 andere personen hebben deze handleiding voltooid.
ZFix
197.270 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
334 Leden
1.701 handleidingen geschreven
3Gids Commentaar
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - Antwoord Deel
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander - Antwoord Deel
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 19,306
