Ga door naar hoofdinhoud
Sony Xperia Z1 Compact Rear Camera Replacement
Wat je nodig hebt
  1. Sony Xperia Z1 Compact Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Xperia Z1 Compact Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Xperia Z1 Compact Rear Camera Replacement: stap 3, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: stap 4, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement, Battery: stap 4, afbeelding 2 van 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Xperia Z1 Compact Rear Camera Replacement: stap 5, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Xperia Z1 Compact Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony Xperia Z1 Compact Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from the device
    Vraag FixBot
    Voeg opmerking toe
  8. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: stap 8, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: stap 8, afbeelding 2 van 2
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony Xperia Z1 Compact Rear Camera Replacement: stap 9, afbeelding 1 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 9, afbeelding 2 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 9, afbeelding 3 van 3
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony Xperia Z1 Compact Rear Camera Replacement: stap 10, afbeelding 1 van 1
    • Remove the back frame.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony Xperia Z1 Compact Rear Camera Replacement: stap 11, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement: stap 11, afbeelding 2 van 2
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony Xperia Z1 Compact Rear Camera Replacement: stap 12, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement: stap 12, afbeelding 2 van 2
    • Remove the external speaker.
    Vraag FixBot
    Voeg opmerking toe
  13. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: stap 13, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: stap 13, afbeelding 2 van 2
    • Remove the square rubber gasket from the camera using the plastic spudger.
    Vraag FixBot
    Voeg opmerking toe
  14. Sony Xperia Z1 Compact Rear Camera Replacement: stap 14, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement: stap 14, afbeelding 2 van 2
    • Remove the black plastic corner still holding in the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  15. Sony Xperia Z1 Compact Rear Camera Replacement: stap 15, afbeelding 1 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 15, afbeelding 2 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 15, afbeelding 3 van 3
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
    Vraag FixBot
    Voeg opmerking toe
  16. Sony Xperia Z1 Compact Rear Camera Replacement: stap 16, afbeelding 1 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 16, afbeelding 2 van 3 Sony Xperia Z1 Compact Rear Camera Replacement: stap 16, afbeelding 3 van 3
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
    Vraag FixBot
    Voeg opmerking toe
  17. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: stap 17, afbeelding 1 van 2 Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: stap 17, afbeelding 2 van 2
    • Disconnect the camera from the motherboard using a spudger.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin Bergstrom
383 Reputatie
3 handleidingen geschreven
1Gids Commentaar
The trouble is that the headphones jack and the monitor cables are unplugged when removing the motherboard and I do not think it is possible to plug them back in from the back side of the phone. I think the monitor needs to be removed for them to be plugged from the front.
natuk - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 38
Altijd: 1,269
