Ga door naar hoofdinhoud
Sony Xperia Z1 - Password Removal, Firmware update with PC Companion
Video overzicht
  1. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 1, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 1, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 1, afbeelding 3 van 3
  2. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 2, afbeelding 1 van 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 2, afbeelding 2 van 2
    • Insert wisdom here.
  3. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 3, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 3, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 3, afbeelding 3 van 3
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 4, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 4, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 4, afbeelding 3 van 3
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  5. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 5, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 5, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 5, afbeelding 3 van 3
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  6. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 6, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 6, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 6, afbeelding 3 van 3
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  7. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 7, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 7, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 7, afbeelding 3 van 3
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
    the link for fastboot drivers is not working for me
    Ali El Ouarzazi - Antwoord
  8. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 8, afbeelding 1 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 8, afbeelding 2 van 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: stap 8, afbeelding 3 van 3
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
Conclusie
19 andere personen hebben deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.466 handleidingen geschreven
3 opmerkingen
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - Antwoord
Great platform to unlock my device.
get Offline Freeware Software’s
Offline Freewarefiles - Antwoord
which version is it? sony companion doesnt let you do it in latest. plz reply
DcKnown by Public - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 23
Altijd: 21,108
