Ga door naar hoofdinhoud
Inleiding
Your device must be switched-on, connected to the internet and it must have installed Google account.
From Android Device manager you can:
- Find the device on the map
- Change the Lock Screen (pass the Password, PIN, Pattern Lock)
- Factory / Hard reset (!!! THIS WILL ERASE YOUR DATA!!!)
If your device is connected to the internet and you have an installed Google account on it, look at this manual.
Video overzicht
  1. Your device must be switched-on, connected to the internet and it must have installed Google account. Your device must be switched-on, connected to the internet and it must have installed Google account.
    • Your device must be switched-on, connected to the internet and it must have installed Google account.
  2. Open: www.google.com/android/devicemanager Enter in your account and Google will start searching your device.
  3. Here you have three options. The first one is "Ring device".
    • Here you have three options.
    • The first one is "Ring device".
  4. The next option is "Lock". Your current lock screen will be replaced with a password lock. Don't use your Google account password Every time I'm using - 1234      :)
    • The next option is "Lock".
    • Your current lock screen will be replaced with a password lock. Don't use your Google account password
    • Every time I'm using - 1234 :)
  5. Now, form Settings > Security you can change your Screen Lock. Now, form Settings > Security you can change your Screen Lock. Now, form Settings > Security you can change your Screen Lock.
    • Now, form Settings > Security you can change your Screen Lock.
  6. Also you can Factory Reset your device. "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device." "If your device is offline, we will perform the factory reset as soon as it goes online."
    • Also you can Factory Reset your device.
    • "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device."
    • "If your device is offline, we will perform the factory reset as soon as it goes online."
  7. That's all. Did you do it successfully? Did you do it successfully?
    • That's all.
    • Did you do it successfully?
Conclusie
193 andere personen hebben deze handleiding voltooid.
ZFix
166.293 Reputatie
305 handleidingen geschreven
Master Techs Lid van Master Techs
Community
287 Leden
818 handleidingen geschreven
Complain loudly to Google about the following message from ADM after trying to over-ride the screen lock with a password: "Since Google has verified that a screen lock is already set, the password you entered won't be needed." THAT'S THE WHOLE F@)_#$) POINT -- You don't know the password and ADM won't let you enter another one to unlock the screen.
Trent Lucas - Antwoord
If you forgot your pattern lock or screen password, ADM will replace it with a new, entered from the customer. You don't need to know the password.
ZFix -
@zFix im trying this method and it says your phone, “your phone is already locked, you cannot put a new password”
can you help in any other method
regards
Haroon Gulzar -
ADM is not replacing the password. It keeps saying "Since Google has verified that a screen lock is already set, the password you entered won't be needed.".
My nephew forgot his password and we couldn't use ADM to reset it. In fact, I set a password on my Moto X to try and reset it from ADM, it says the same thing and won't reset it.
sodapop jam - Antwoord
ADM won't remove the password. Instead, it will generate a tmp password and you can use it to unlock the phone. Then you need to set a few passcode for the phone. The tutorial has detailed explanation on this issue: http://bit.ly/28SHO3G
kersonzine -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 98
Afgelopen 7 Dagen: 742
Afgelopen 30 Dagen: 3,493
Altijd: 412,012
