Ga door naar hoofdinhoud
Sony Xperia XZ2 LCD Screen Replacement
Wat je nodig hebt
    1. Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Sony Xperia XZ2 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
      • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
      • The phone gets very hot and can hurt the user handling it.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Xperia XZ2 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Sony Xperia XZ2 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Sony Xperia XZ2 LCD Screen Replacement: stap 2, afbeelding 3 van 3
      • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
      • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Xperia XZ2 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Sony Xperia XZ2 LCD Screen Replacement: stap 3, afbeelding 2 van 2
      • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
      • The screen is still attached by a connector, so do not pull the pieces apart.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Xperia XZ2 LCD Screen Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      $3.99
      • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Xperia XZ2 LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Gently remove the connector by using a spudger to pop it off.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Matthew Ionescu
445 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G5, White Winter 2019 Lid van Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
4 Leden
35 handleidingen geschreven
4Gids Commentaar
Worked perfectly fine for my xz2 compact
Maria Schrenk - Antwoord Deel
Hi, someone knows how to glue it back. I read that if I use B-6000 glue it will damage my screen.
Diego Covenas - Antwoord Deel
Double-sided adhesive should do the trick. For example 2mm Universal 3M Adhesive Tape should be preferred to glue.
Célestin Taramarcaz - Antwoord Deel
The XZ2 Compact has the same screen connector+clip.
My screen came without the upper speaker grille (plastic+fabric). When I tried to remove the glue from the old one the fabric got delaminated from the plastic. Tip: Check if the grille is in place before gluing back!
Dimitrios Josef Moustos - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 99
Altijd: 11,831
