Inleiding
This is a guide to help you remove the LCD Screen on the Sony Xperia XA2 Ultra. Review the troubleshooting page to make sure the screen is broken.
Warning: The removal of the screen could permanently damage it. Only take these steps if your current screen is broken.
Follow all available guides to make sure that the following parts have been removed:
- Sim Card Tray
- Back Cover
- Motherboard Bracket
- Rear Camera
- Front Camera
- Headphone Jack
- Motherboard
- Speaker
- Charging Port
- Vibration Motor
- Battery
Before taking any steps to open the phone, make sure that it is turned completely.
Be aware that the device will heat up when using a heat gun (or something similar). Continue with caution.
Wat je nodig hebt
Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using the tweezers, pry underneath the vibration motor and pull from its place.
Use a pair of tweezers to remove the rear-facing camera.
Use a pair of tweezers to remove the magnetic tape covering the front-facing camera.
Use a pair of tweezers to remove the front-facing camera.
Grab and twist the black battery tab with a pair of precision tweezers.
Do this again with the black tab under the power button flex cable.
Één andere persoon heeft deze handleiding voltooid.
