Inleiding
This guide will help you remove the battery in the Sony Xperia XA2 Ultra.
Before using this guide, review the troubleshooting page to see if any battery management tips could help.
Before taking any steps to open the phone, make sure that it is completely turned off.
Be aware that when using a heat gun (or something similar) that the device will heat up. Continue with caution.
Wat je nodig hebt
Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
Use a pair of tweezers to remove the rear-facing camera.
Use a pair of tweezers to remove the magnetic tape covering the front-facing camera.
Use a pair of tweezers to remove the front-facing camera.
Grab and twist the black battery tab with a pair of precision tweezers.
Do this again with the black tab under the power button flex cable.
