Ga door naar hoofdinhoud
Sony Xperia XA1 Rear Camera Replacement
Wat je nodig hebt
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: stap 1, afbeelding 1 van 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: stap 1, afbeelding 2 van 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: stap 1, afbeelding 3 van 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: stap 2, afbeelding 1 van 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: stap 2, afbeelding 2 van 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: stap 2, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: stap 3, afbeelding 1 van 3 Sony Xperia XA1 Rear Camera Replacement: stap 3, afbeelding 2 van 3 Sony Xperia XA1 Rear Camera Replacement: stap 3, afbeelding 3 van 3
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: stap 4, afbeelding 1 van 3 Sony Xperia XA1 Rear Camera Replacement: stap 4, afbeelding 2 van 3 Sony Xperia XA1 Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
Conclusie
sebastianh034
253 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 14
Altijd: 178
