Ga door naar hoofdinhoud
Sony Vaio VGN-SZ120P Keyboard Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-SZ120P Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Keyboard Replacement: stap 2, afbeelding 1 van 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Keyboard Replacement: stap 4, afbeelding 1 van 2 Sony Vaio VGN-SZ120P Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Keyboard Replacement: stap 5, afbeelding 1 van 2 Sony Vaio VGN-SZ120P Keyboard Replacement: stap 5, afbeelding 2 van 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Brooks
312 Reputatie
4 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
61 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 5,602
