Ga door naar hoofdinhoud
Sony Vaio PCG-F420 RAM Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-F420 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Vaio PCG-F420 RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Vaio PCG-F420 RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Remove the screw holding the RAM cover down.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Vaio PCG-F420 RAM Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to lift the covering, revealing the RAM modules inside the computer.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Vaio PCG-F420 RAM Replacement: stap 5, afbeelding 1 van 1
    • To remove the RAM currently inside the computer, gently pull out the white tabs on each side of the RAM module.
    • The RAM will pop up at an angle where it can be pulled out without damaging the socket.
    • Remove the RAM module by pulling at the same angle the RAM is at.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Vaio PCG-F420 RAM Replacement: stap 6, afbeelding 1 van 1
    • To insert the new RAM module, match the notch in the middle of the gold edge of the RAM to the notch in the laptop.
    • Insert the RAM at the same angle the other module came out at and make sure the end of the ram is actually in the slot. Gently push down on the RAM until it clicks in.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Therin Irwin
22 Reputatie
2 handleidingen geschreven
Cal Poly, Team 29-77, Johann Spring 2010 Lid van Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 2,748
