Ga door naar hoofdinhoud
Sony Vaio PCG-F420 Display Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-F420 Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Vaio PCG-F420 Display Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Vaio PCG-F420 Display Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Vaio PCG-F420 Display Replacement: stap 4, afbeelding 1 van 1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Vaio PCG-F420 Display Replacement: stap 5, afbeelding 1 van 1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Vaio PCG-F420 Display Replacement: stap 6, afbeelding 1 van 1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony Vaio PCG-F420 Display Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony Vaio PCG-F420 Display Replacement: stap 8, afbeelding 1 van 2 Sony Vaio PCG-F420 Display Replacement: stap 8, afbeelding 2 van 2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony Vaio PCG-F420 Display Replacement: stap 9, afbeelding 1 van 1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony Vaio PCG-F420 Display Replacement, Display: stap 10, afbeelding 1 van 1
    • Use tweezers to remove the rubber covers on the four screws at the corners near the display.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony Vaio PCG-F420 Display Replacement: stap 11, afbeelding 1 van 1
    • With the screwdriver, unscrew the four screws that attached the front bezel panel with the display assembly, as shown in the image.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony Vaio PCG-F420 Display Replacement: stap 12, afbeelding 1 van 1
    • Using a spudger or another flat-headed tool, pry away the front bezel panel from the display assembly.
    • Apply pressure carefully while placing the spudger on the seam connecting the front and rear bezels.
    • Clips attaching the two panels should start to come apart.
    Vraag FixBot
    Voeg opmerking toe
  13. Sony Vaio PCG-F420 Display Replacement: stap 13, afbeelding 1 van 3 Sony Vaio PCG-F420 Display Replacement: stap 13, afbeelding 2 van 3 Sony Vaio PCG-F420 Display Replacement: stap 13, afbeelding 3 van 3
    • There are a total of 14 clips holding the two bezel panels together. Be careful when unclipping all of them.After all the clips are off, the bezel will just pop right off the display panel.
    • Remove all 14 clips and place them in a safe area.
    • Once all 14 clips are removed the bezel can be removed.
    Vraag FixBot
    Voeg opmerking toe
  14. Sony Vaio PCG-F420 Display Replacement: stap 14, afbeelding 1 van 1
    • Find and unscrew the four gold Philips-head screws that attach the display to the rear bezel of the display assembly.
    • Take care not to immediately remove the display, as cables are still attached.
    Vraag FixBot
    Voeg opmerking toe
  15. Sony Vaio PCG-F420 Display Replacement: stap 15, afbeelding 1 van 2 Sony Vaio PCG-F420 Display Replacement: stap 15, afbeelding 2 van 2
    • Locate the ribbon cable slot and the two-pin backlight cable. These are essential connections for the display.
    • Gently, but firmly, grasp the ribbon cable near its connection point.
    • Use steady, even pressure to pull the ribbon cable out of its socket. Be careful not to use excessive force.
    • Similarly, disconnect the two-pin backlight cable with gentle and controlled force. Ensure you disconnect both cables securely to avoid any damage during removal.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Therin Irwin
22 Reputatie
2 handleidingen geschreven
Cal Poly, Team 29-77, Johann Spring 2010 Lid van Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 3,168
