Ga door naar hoofdinhoud
Sony Vaio PCG-4G1L Keyboard Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Vaio PCG-4G1L Keyboard Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-4G1L Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide battery release toggle switch towards the "RELEASE" print.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Vaio PCG-4G1L Keyboard Replacement: stap 3, afbeelding 1 van 3 Sony Vaio PCG-4G1L Keyboard Replacement: stap 3, afbeelding 2 van 3 Sony Vaio PCG-4G1L Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Vaio PCG-4G1L Keyboard Replacement: stap 5, afbeelding 1 van 2 Sony Vaio PCG-4G1L Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Vaio PCG-4G1L Keyboard Replacement: stap 6, afbeelding 1 van 3 Sony Vaio PCG-4G1L Keyboard Replacement: stap 6, afbeelding 2 van 3 Sony Vaio PCG-4G1L Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Cole Collins
211 Reputatie
4 handleidingen geschreven
USF Tampa, Team 2-3, Cagle Fall 2016 Lid van USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 55
Altijd: 1,292
