Ga door naar hoofdinhoud
Sony Vaio PCG-4G1L Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 2, afbeelding 2 van 2
    • Slide battery release toggle switch towards the "RELEASE" print.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 3, afbeelding 1 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 3, afbeelding 2 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 3, afbeelding 3 van 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: stap 4, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 5, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 5, afbeelding 2 van 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 6, afbeelding 1 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 6, afbeelding 2 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 6, afbeelding 3 van 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony Vaio PCG-4G1L Hard Drive  Replacement, Network Antenna: stap 7, afbeelding 1 van 1
    • Swivel the Network Antenna up so that it points upward.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 8, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 8, afbeelding 2 van 2
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: stap 9, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: stap 9, afbeelding 2 van 2
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 10, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 10, afbeelding 2 van 2
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 11, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  12. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 12, afbeelding 1 van 1
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
    Vraag FixBot
    Voeg opmerking toe
  13. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 13, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 13, afbeelding 2 van 2
    • Disconnect the ribbon cable by pulling straight up with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  14. Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: stap 14, afbeelding 1 van 2 Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: stap 14, afbeelding 2 van 2
    • Remove three 5 mm Phillips #0 flat head screws using a Bit Driver with a Phillips PH000 bit.
    • Remove the bracket with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  15. Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 15, afbeelding 1 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 15, afbeelding 2 van 3 Sony Vaio PCG-4G1L Hard Drive  Replacement: stap 15, afbeelding 3 van 3
    • Using the plastic opening tool, pry out the side of the hard drive.
    • The hard drive should easily disconnect from the connector.
    • Slide the hard drive out, towards the left side of the case, while your fingers apply pressure to the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Diego Fabiano
195 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-3, Cagle Fall 2016 Lid van USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 84
Altijd: 12,317
