Ga door naar hoofdinhoud
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
Wat je nodig hebt
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 1, afbeelding 1 van 1
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 2, afbeelding 1 van 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 2, afbeelding 2 van 3 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 2, afbeelding 3 van 3
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 3, afbeelding 1 van 1
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 4, afbeelding 1 van 1
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 5, afbeelding 1 van 2 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: stap 5, afbeelding 2 van 2
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Olivia
605 Reputatie
5 handleidingen geschreven
5 opmerkingen
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Antwoord
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Antwoord
Where i buy flexi
msobirin48 - Antwoord
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Antwoord
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 38
Altijd: 4,428
