Ga door naar hoofdinhoud
Sony VAIO PCG-933A Keyboard Replacement
Wat je nodig hebt
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Sony VAIO PCG-933A Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony VAIO PCG-933A Keyboard Replacement: stap 2, afbeelding 1 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 2, afbeelding 2 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 2, afbeelding 3 van 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony VAIO PCG-933A Keyboard Replacement: stap 4, afbeelding 1 van 2 Sony VAIO PCG-933A Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony VAIO PCG-933A Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip the computer so the key board is facing up.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony VAIO PCG-933A Keyboard Replacement: stap 6, afbeelding 1 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 6, afbeelding 2 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony VAIO PCG-933A Keyboard Replacement: stap 7, afbeelding 1 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 7, afbeelding 2 van 3 Sony VAIO PCG-933A Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sara Lillard
165 Reputatie
8 handleidingen geschreven
Cal Poly, Team 12-36, Maness Spring 2011 Lid van Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 2,224
