Ga door naar hoofdinhoud
Sony Tablet S Charging Connector Replacement
Wat je nodig hebt
    1. Sony Tablet S Charging Connector Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement, Battery: stap 1, afbeelding 2 van 2
      • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
      • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Tablet S Charging Connector Replacement: stap 2, afbeelding 1 van 1
      • Remove the two 10mm Phillips #0 screws located under the grips.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Tablet S Charging Connector Replacement: stap 3, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement: stap 3, afbeelding 2 van 2
      • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
      • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Tablet S Charging Connector Replacement: stap 4, afbeelding 1 van 1
      • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Tablet S Charging Connector Replacement: stap 5, afbeelding 1 van 1
      • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
      • Use caution when removing the cable, as the socket is very fragile.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony Tablet S Charging Connector Replacement: stap 6, afbeelding 1 van 1
      • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony Tablet S Charging Connector Replacement: stap 7, afbeelding 1 van 1
      • Slide the bottom grey cover piece away from the body and remove it.
      • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony Tablet S Charging Connector Replacement: stap 8, afbeelding 1 van 1
      • Remove the five 4mm Phillips #000 screws.
      • Remove the two 5mm Phillips #000 screws holding the charger in place.
      Vraag FixBot
      Voeg opmerking toe
    9. Sony Tablet S Charging Connector Replacement: stap 9, afbeelding 1 van 3 Sony Tablet S Charging Connector Replacement: stap 9, afbeelding 2 van 3 Sony Tablet S Charging Connector Replacement: stap 9, afbeelding 3 van 3
      • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
      • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
      Vraag FixBot
      Voeg opmerking toe
    10. Sony Tablet S Charging Connector Replacement: stap 10, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement: stap 10, afbeelding 2 van 2
      • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
      Vraag FixBot
      Voeg opmerking toe
    11. Sony Tablet S Charging Connector Replacement: stap 11, afbeelding 1 van 1
      • Remove the three 5mm Phillips #0 screws securing the original battery.
      Vraag FixBot
      Voeg opmerking toe
    12. Sony Tablet S Charging Connector Replacement: stap 12, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement: stap 12, afbeelding 2 van 2
      • Use the spudger to pop the battery loose and remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Tablet S Charging Connector Replacement, Charging Connector: stap 13, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement, Charging Connector: stap 13, afbeelding 2 van 2
      • Unscrew the single 5mm Phillips #000 screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Tablet S Charging Connector Replacement: stap 14, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement: stap 14, afbeelding 2 van 2
      • Peel up the tape securing the assembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Tablet S Charging Connector Replacement: stap 15, afbeelding 1 van 3 Sony Tablet S Charging Connector Replacement: stap 15, afbeelding 2 van 3 Sony Tablet S Charging Connector Replacement: stap 15, afbeelding 3 van 3
      • Use a spudger to disengage the zero insertion force latch securing the copper ribbon cable.
      • Pull away the ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Tablet S Charging Connector Replacement: stap 16, afbeelding 1 van 2 Sony Tablet S Charging Connector Replacement: stap 16, afbeelding 2 van 2
      • Disconnect the charging assembly from the pin connector.
      • Pull on it very gently; the socket is very fragile.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Tablet S Charging Connector Replacement: stap 17, afbeelding 1 van 1
      • Remove the assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Austin Mann
287 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-5, Passmore Fall 2016 Lid van USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Leden
1Gids Commentaar
Thank you it helped me. :)
e_hlpr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 43
Altijd: 3,695
