Ga door naar hoofdinhoud
Sony SRS-XB43 Speaker Replacement
Wat je nodig hebt
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: stap 1, afbeelding 1 van 2 Sony SRS-XB43 Speaker Replacement, Faceplate: stap 1, afbeelding 2 van 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: stap 4, afbeelding 1 van 2 Sony SRS-XB43 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 Sony SRS-XB43 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 Sony SRS-XB43 Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: stap 7, afbeelding 1 van 2 Sony SRS-XB43 Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the two individual speakers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bishoy Mikhail
253 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 53
Altijd: 991
