Ga door naar hoofdinhoud
Sony SRS-XB43 Battery Replacement
Wat je nodig hebt
  1. Sony SRS-XB43 Battery Replacement, Faceplate: stap 1, afbeelding 1 van 2 Sony SRS-XB43 Battery Replacement, Faceplate: stap 1, afbeelding 2 van 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Battery Replacement: stap 4, afbeelding 1 van 2 Sony SRS-XB43 Battery Replacement: stap 4, afbeelding 2 van 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Sony SRS-XB43 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Battery Replacement: stap 6, afbeelding 1 van 3 Sony SRS-XB43 Battery Replacement: stap 6, afbeelding 2 van 3 Sony SRS-XB43 Battery Replacement: stap 6, afbeelding 3 van 3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Battery Replacement: stap 7, afbeelding 1 van 2 Sony SRS-XB43 Battery Replacement: stap 7, afbeelding 2 van 2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Battery Replacement: stap 8, afbeelding 1 van 2 Sony SRS-XB43 Battery Replacement: stap 8, afbeelding 2 van 2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
Conclusie
Luke Escobar
159 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Leden
5 handleidingen geschreven
Één opmerking
So, where can we buy a new battery to use these instructions for replacing it ?
Doubletap - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 166
Altijd: 2,295
