Ga door naar hoofdinhoud
Sony Reader Touch Edition PRS-600 Power Button Replacement
Wat je nodig hebt
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 2, afbeelding 1 van 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 3, afbeelding 1 van 1
      • This is what the device should look like once the back cover panel has been removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: stap 4, afbeelding 1 van 1
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 5, afbeelding 1 van 1
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: stap 6, afbeelding 1 van 1
      • Remove the stylus from the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 7, afbeelding 1 van 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 7, afbeelding 2 van 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: stap 7, afbeelding 3 van 3
      • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
      • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
      • Pry apart off the top panel of the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Zachary Jeffers
412 Reputatie
4 handleidingen geschreven
Clemson, Team 1-4, Benson Fall 2014 Lid van Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 62
Altijd: 1,081
