Ga door naar hoofdinhoud
Sony Pulse Elite Edition Speaker Replacement
Wat je nodig hebt
  1. Sony Pulse Elite Edition Speaker Replacement, Identifying Earpiece: stap 1, afbeelding 1 van 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Pulse Elite Edition Speaker Replacement, Ear Cushion Removal: stap 2, afbeelding 1 van 2 Sony Pulse Elite Edition Speaker Replacement, Ear Cushion Removal: stap 2, afbeelding 2 van 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Pulse Elite Edition Speaker Replacement, Outer Ear Rim Removal: stap 3, afbeelding 1 van 2 Sony Pulse Elite Edition Speaker Replacement, Outer Ear Rim Removal: stap 3, afbeelding 2 van 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Pulse Elite Edition Speaker Replacement, Remove Speaker Housing: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Pulse Elite Edition Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Sony Pulse Elite Edition Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Locate the junction of the electrical speaker and the plastic speaker housing.
    • Use the spudger to sever the glue at this junction.
    • Remove the electrical speaker from the speaker housing.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony Pulse Elite Edition Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use super glue to fasten the replacement speaker into the speaker housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Armon Davani
400 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 3,645
