Ga door naar hoofdinhoud
Sony Pulse Elite Edition Battery Replacement
Wat je nodig hebt
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: stap 1, afbeelding 1 van 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: stap 2, afbeelding 1 van 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: stap 2, afbeelding 2 van 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: stap 3, afbeelding 1 van 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: stap 3, afbeelding 2 van 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: stap 5, afbeelding 1 van 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: stap 5, afbeelding 2 van 2
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Chris Echter
871 Reputatie
4 handleidingen geschreven
8Gids Commentaar
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Antwoord Deel
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Antwoord Deel
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Antwoord Deel
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Antwoord Deel
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 151
Altijd: 14,048
