Ga door naar hoofdinhoud
Sony PlayStation Camera Microphone Array Replacement
Wat je nodig hebt
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: stap 1, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: stap 1, afbeelding 2 van 2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony PlayStation Camera Microphone Array Replacement: stap 2, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 2, afbeelding 2 van 2
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony PlayStation Camera Microphone Array Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, remove the cap holding the cable grommet in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Sony PlayStation Camera Microphone Array Replacement: stap 4, afbeelding 1 van 1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    Vraag FixBot
    Voeg opmerking toe
  5. Sony PlayStation Camera Microphone Array Replacement: stap 5, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 5, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    Vraag FixBot
    Voeg opmerking toe
  6. Sony PlayStation Camera Microphone Array Replacement: stap 6, afbeelding 1 van 1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    Vraag FixBot
    Voeg opmerking toe
  7. Sony PlayStation Camera Microphone Array Replacement: stap 7, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 7, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    Vraag FixBot
    Voeg opmerking toe
  8. Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 1 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 2 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 8, afbeelding 3 van 3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Sony PlayStation Camera Microphone Array Replacement: stap 9, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 9, afbeelding 2 van 2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    Vraag FixBot
    Voeg opmerking toe
  10. Sony PlayStation Camera Microphone Array Replacement: stap 10, afbeelding 1 van 2 Sony PlayStation Camera Microphone Array Replacement: stap 10, afbeelding 2 van 2
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 1 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 2 van 3 Sony PlayStation Camera Microphone Array Replacement: stap 11, afbeelding 3 van 3
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua Gates
268 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-5, Passmore Spring 2017 Lid van USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 65
Altijd: 7,791
