Ga door naar hoofdinhoud
Sony PlayStation 3D Display Control Buttons Replacement
Wat je nodig hebt
    1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: stap 1, afbeelding 1 van 2 Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: stap 1, afbeelding 2 van 2
      • Remove the base by pushing in the button and sliding out the unit.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony PlayStation 3D Display Control Buttons Replacement: stap 2, afbeelding 1 van 3 Sony PlayStation 3D Display Control Buttons Replacement: stap 2, afbeelding 2 van 3 Sony PlayStation 3D Display Control Buttons Replacement: stap 2, afbeelding 3 van 3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony PlayStation 3D Display Control Buttons Replacement: stap 3, afbeelding 1 van 2 Sony PlayStation 3D Display Control Buttons Replacement: stap 3, afbeelding 2 van 2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony PlayStation 3D Display Control Buttons Replacement: stap 4, afbeelding 1 van 3 Sony PlayStation 3D Display Control Buttons Replacement: stap 4, afbeelding 2 van 3 Sony PlayStation 3D Display Control Buttons Replacement: stap 4, afbeelding 3 van 3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: stap 5, afbeelding 1 van 1
      • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony PlayStation 3D Display Control Buttons Replacement: stap 6, afbeelding 1 van 2 Sony PlayStation 3D Display Control Buttons Replacement: stap 6, afbeelding 2 van 2
      • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tia McNaughton
379 Reputatie
3 handleidingen geschreven
Cal Poly, Team 12-16, Maness Fall 2015 Lid van Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 997
