Inleiding
In this guide you will learn how to replace a broken or old needle on a Sony PS1100. The green needle cartridge is one solid component, that must be replaced together. The needle cannot simply be replaced by itself. The Sony VL-30G is the proper cartridge for the PS1100 Record player, and can be found in most record shops.
For More Troubleshooting click the link: Sony PS1100 Troubleshooting
Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
Firmly grip both sides of the cartridge with your thumb and index fingers.
CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
Één andere persoon heeft deze handleiding voltooid.
