Ga door naar hoofdinhoud
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: stap 1, afbeelding 1 van 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: stap 1, afbeelding 2 van 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: stap 1, afbeelding 3 van 3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: stap 2, afbeelding 1 van 1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: stap 3, afbeelding 1 van 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: stap 3, afbeelding 2 van 2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: stap 4, afbeelding 1 van 1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
L Cis
110 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-8, Donnelly Fall 2014 Lid van USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 4,584
