Ga door naar hoofdinhoud
Sony PS-LX300USB Drive Belt Replacement
Wat je nodig hebt
    1. Sony PS-LX300USB Drive Belt Replacement, Drive Belt: stap 1, afbeelding 1 van 2 Sony PS-LX300USB Drive Belt Replacement, Drive Belt: stap 1, afbeelding 2 van 2
      • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony PS-LX300USB Drive Belt Replacement: stap 2, afbeelding 1 van 1
      • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
      • If the drive belt is hooked around the motor pulley, unhook it.
      • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony PS-LX300USB Drive Belt Replacement: stap 3, afbeelding 1 van 1
      • Grasping the platter by its two inner holes, lift it upwards.
      • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
      • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony PS-LX300USB Drive Belt Replacement: stap 4, afbeelding 1 van 2 Sony PS-LX300USB Drive Belt Replacement: stap 4, afbeelding 2 van 2
      • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
      • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
19 andere personen hebben deze handleiding voltooid.
Michelle Jakab
633 Reputatie
1 Handleiding geschreven
Cal Poly, Team S8-G3, Banghart Fall 2017 Lid van Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Leden
15 handleidingen geschreven
3Gids Commentaar
Thank you for posting!
Jeanine Haven - Antwoord Deel
Thank you for posting this! My belt slipped and I could not figure this out thanks to you I saw how simple a process the repair. Many times thank you
Thank you for this post. I freaked out when belt became detached. I had moved turntable several times to resolve a connection issue and OOPS! Very concise instructions with clear pictures. Awesome!!
Eric Doner - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 187
Altijd: 20,953
