Ga door naar hoofdinhoud
Sony NEX-7 Top and Back Shell Replacement
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Sony NEX-7 Top and Back Shell Replacement, Battery: stap 1, afbeelding 1 van 2 Sony NEX-7 Top and Back Shell Replacement, Battery: stap 1, afbeelding 2 van 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Top and Back Shell Replacement: stap 2, afbeelding 1 van 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Top and Back Shell Replacement: stap 3, afbeelding 1 van 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 Top and Back Shell Replacement, SD card: stap 4, afbeelding 1 van 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
  5. Sony NEX-7 Top and Back Shell Replacement, Lens: stap 5, afbeelding 1 van 2 Sony NEX-7 Top and Back Shell Replacement, Lens: stap 5, afbeelding 2 van 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
  6. Sony NEX-7 Top and Back Shell Replacement, Top and Back Shell: stap 6, afbeelding 1 van 1
    • Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
  7. Sony NEX-7 Top and Back Shell Replacement: stap 7, afbeelding 1 van 2 Sony NEX-7 Top and Back Shell Replacement: stap 7, afbeelding 2 van 2
    • Remove the 5/32" #00 screw at the top of the compartment using the Phillips #00 screwdriver.
    • Remove the two 5/32" #00 screws from inside the compartment using the Phillips #00 screwdriver.
  8. Sony NEX-7 Top and Back Shell Replacement: stap 8, afbeelding 1 van 2 Sony NEX-7 Top and Back Shell Replacement: stap 8, afbeelding 2 van 2
    • Close the battery door by pushing it down until it latches shut.
  9. Sony NEX-7 Top and Back Shell Replacement: stap 9, afbeelding 1 van 1
    • Looking at the left side of the camera, lift open the door that has 'HDMI' written on it.
    • Remove the two visible 5/32" #00 screws using the Phillips #00 screwdriver.
  10. Sony NEX-7 Top and Back Shell Replacement: stap 10, afbeelding 1 van 3 Sony NEX-7 Top and Back Shell Replacement: stap 10, afbeelding 2 van 3 Sony NEX-7 Top and Back Shell Replacement: stap 10, afbeelding 3 van 3
    • Looking at the back of the camera, press the button with a lightning bolt on it to pop the flash open.
    • Remove the three 5/32" screws from within the flash compartment using the Phillips #00 screwdriver.
    • Close the flash compartment.
  11. Sony NEX-7 Top and Back Shell Replacement: stap 11, afbeelding 1 van 1
    • The top of the camera is attached by three wires and a ribbon cable. Remove the top slowly and gently!
    • Lift the top of the camera off of the body.
    • Let the top hang to the side so you have room to work with the components inside the device.
  12. Sony NEX-7 Top and Back Shell Replacement: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers or your fingers, gently remove the blue ribbon cable from the port.
  13. Sony NEX-7 Top and Back Shell Replacement: stap 13, afbeelding 1 van 2 Sony NEX-7 Top and Back Shell Replacement: stap 13, afbeelding 2 van 2
    • Place the tips of your tweezers on either side of the red jack.
    • Gently pull the red plug out of the jack.
    • Repeat those steps for the yellow jack and plug.
    • Now that the top is free, place it aside for later.
  14. Sony NEX-7 Top and Back Shell Replacement: stap 14, afbeelding 1 van 1
    • Lift the LCD screen with your fingers such that the screen is bent slightly away from the camera.
  15. Sony NEX-7 Top and Back Shell Replacement: stap 15, afbeelding 1 van 3 Sony NEX-7 Top and Back Shell Replacement: stap 15, afbeelding 2 van 3 Sony NEX-7 Top and Back Shell Replacement: stap 15, afbeelding 3 van 3
    • Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
    • Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
    • The back panel will be easier to take off if the LCD screen has been extended away from the camera by about 60 degrees.
    • Set the back panel aside.
Conclusie
Jay Miley
5.329 Reputatie
13 handleidingen geschreven
Cal Poly, Team 10-55, Amido Spring 2014 Lid van Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Leden
37 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 156
