Ga door naar hoofdinhoud
Sony NEX-5R Motherboard Replacement
Wat je nodig hebt
    1. Sony NEX-5R Motherboard Replacement, Front Case: stap 1, afbeelding 1 van 2 Sony NEX-5R Motherboard Replacement, Front Case: stap 1, afbeelding 2 van 2
      • Open the battery pack door by moving the slider to "OPEN".
      • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-5R Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-5R Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony NEX-5R Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Use the spudger to raise the corner of the case from the camera.
      • One component of the front case should now be separate from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-5R Motherboard Replacement, Rear Case: stap 4, afbeelding 1 van 1
      • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-5R Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-5R Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony NEX-5R Motherboard Replacement: stap 7, afbeelding 1 van 1
      • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony NEX-5R Motherboard Replacement: stap 8, afbeelding 1 van 2 Sony NEX-5R Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
      • The back frame is fragile, so use the spudger gently.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony NEX-5R Motherboard Replacement: stap 9, afbeelding 1 van 1
      • The back case should now be removed and look like this.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-5R Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
      • Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-5R Motherboard Replacement: stap 11, afbeelding 1 van 1
      • Remove the copper 2.25mm phillips head screw from the side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-5R Motherboard Replacement: stap 12, afbeelding 1 van 3 Sony NEX-5R Motherboard Replacement: stap 12, afbeelding 2 van 3 Sony NEX-5R Motherboard Replacement: stap 12, afbeelding 3 van 3
      • Use the spudger tool to unhook the neck strap anchor from the side of the camera with the navigation buttons.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony NEX-5R Motherboard Replacement: stap 13, afbeelding 1 van 1
      • Remove the six copper 2.25mm phillips head screws from the top of the motherboard assembly on the camera
      Vraag FixBot
      Voeg opmerking toe
    5. Sony NEX-5R Motherboard Replacement: stap 14, afbeelding 1 van 1
      • Flip the main navigation button up behind the camera to further expose the frame
      Vraag FixBot
      Voeg opmerking toe
    6. Sony NEX-5R Motherboard Replacement: stap 15, afbeelding 1 van 1
      • Lift the LCD screen straight up and off of the camera. The motherboard frame is attached and the assembly will easily separate from the camera.
      • The lead connecting the LCD screen and the motherboard is fragile. Be careful not to damage the wiring or either end of the leads.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony NEX-5R Motherboard Replacement: stap 16, afbeelding 1 van 2 Sony NEX-5R Motherboard Replacement: stap 16, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Remove the lead connecting the LCD screen and frame assembly to the motherboard. Using tweezers, pull straight out from the lead to disconnect
      • Always work carefully when removing internal leads. These wires and ribbons are fragile.
      • The LCD screen and frame should now be separate from the main camera and appear as shown in the image
      Vraag FixBot
      Voeg opmerking toe
    8. Sony NEX-5R Motherboard Replacement: stap 17, afbeelding 1 van 1
      • Remove the small wire lead from the motherboard using the tweezers. Firmly grasp the lead wire near the connection and pull up from the motherboard at an angle. The lead will snap off of the mount.
      Vraag FixBot
      Voeg opmerking toe
    9. Sony NEX-5R Motherboard Replacement: stap 18, afbeelding 1 van 1
      • On the top left corner of the motherboard, unhook the black grommet from the housing by pinching the small tab with the tweezers and lifting up.
      Vraag FixBot
      Voeg opmerking toe
    10. Sony NEX-5R Motherboard Replacement: stap 19, afbeelding 1 van 3 Sony NEX-5R Motherboard Replacement: stap 19, afbeelding 2 van 3 Sony NEX-5R Motherboard Replacement: stap 19, afbeelding 3 van 3
      • On the top left side of the motherboard, remove the first lead from housing using the tweezers. Firmly grasp the lead with tweezers and pull straight out from the housing.
      Vraag FixBot
      Voeg opmerking toe
    11. Sony NEX-5R Motherboard Replacement: stap 20, afbeelding 1 van 1
      • Next, remove the first lead on the right side of the motherboard. Using tweezers, tightly grasp the lead and pull straight out from the housing.
      Vraag FixBot
      Voeg opmerking toe
    12. Sony NEX-5R Motherboard Replacement: stap 21, afbeelding 1 van 1
      • Remove the next lead on the side of the motherboard. For this lead, you may have to grasp it on either side with the tweezers as shown due to the lack of room beneath the lead. When securely grasped, pull straight out of the housing to remove the lead.
      Vraag FixBot
      Voeg opmerking toe
    13. Sony NEX-5R Motherboard Replacement: stap 22, afbeelding 1 van 1
      • Remove the final lead on the opposite side of the motherboard with tweezers. Tightly hold and the lead on either side and pull straight out of the housing to disconnect.
      Vraag FixBot
      Voeg opmerking toe
    14. Sony NEX-5R Motherboard Replacement: stap 23, afbeelding 1 van 1
      • On the lower side of the motherboard, you must remove the small metal frame that covers the socket-lead. Pinch the frame on each side with the tweezers and lift up to easily remove it.
      Vraag FixBot
      Voeg opmerking toe
    15. Sony NEX-5R Motherboard Replacement: stap 24, afbeelding 1 van 1
      • Pinch the cylindrical socket lead on each side with tweezers and lift out from its housing to remove the socket-lead.
      Vraag FixBot
      Voeg opmerking toe
    16. Sony NEX-5R Motherboard Replacement: stap 25, afbeelding 1 van 3 Sony NEX-5R Motherboard Replacement: stap 25, afbeelding 2 van 3 Sony NEX-5R Motherboard Replacement: stap 25, afbeelding 3 van 3
      • With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
      • The removed motherboard and camera body should now appear as shown.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Emily Trujillo
1.153 Reputatie
6 handleidingen geschreven
Cal Poly, Team 8-9, Regan Spring 2014 Lid van Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Leden
14 handleidingen geschreven
3Gids Commentaar
I have a Sony NEX-6 mirrorless...Is the process essentially the same?
Emily - Antwoord Deel
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
Norulhuda Azharruddin - Antwoord Deel
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
Harbert Wolfstein - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 64
Altijd: 9,354
