Ga door naar hoofdinhoud
Sony ICF-C1T Tuner Dial Replacement
Wat je nodig hebt
    1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: stap 1, afbeelding 1 van 1
      • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
      • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony ICF-C1T Tuner Dial Replacement: stap 2, afbeelding 1 van 1
      • Use the opening tool to pry apart the edges of the top and side portions of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony ICF-C1T Tuner Dial Replacement: stap 3, afbeelding 1 van 2 Sony ICF-C1T Tuner Dial Replacement: stap 3, afbeelding 2 van 2
      • Separate the device by gently pulling up on the top portion.
      • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony ICF-C1T Tuner Dial Replacement: stap 4, afbeelding 1 van 2 Sony ICF-C1T Tuner Dial Replacement: stap 4, afbeelding 2 van 2
      • To remove the motherboard, gently pull apart the sides of the device.
      • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
      • Be careful of sharp pieces on the motherboard.
      • Having help for this step might make things quicker and easier.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 1 van 3 Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 2 van 3 Sony ICF-C1T Tuner Dial Replacement: stap 5, afbeelding 3 van 3
      • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Megan
275 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Thanks, this was not fun but the guide helped.
Campbell Kerr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 43
Altijd: 2,502
