Inleiding
If your microphone is not functioning correctly, use this guide to remove and replace it. This guide requires soldering.
Wat je nodig hebt
Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
Één andere persoon heeft deze handleiding voltooid.
