Ga door naar hoofdinhoud
Sony H.ear On 2 Motherboard Replacement
Wat je nodig hebt
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Sony H.ear On 2 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: stap 2, afbeelding 1 van 2 Sony H.ear On 2 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: stap 3, afbeelding 1 van 3 Sony H.ear On 2 Motherboard Replacement: stap 3, afbeelding 2 van 3 Sony H.ear On 2 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see Hoe moet je (de-)solderen? for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: stap 4, afbeelding 1 van 2 Sony H.ear On 2 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Conclusie
Michael Long
131 Reputatie
1 Handleiding geschreven
Cal Poly, Team S9-G11, Maness Spring 2019 Lid van Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Leden
16 handleidingen geschreven
Één opmerking
where can i find a replacement motherboard for these headphones?
MTL - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,512
