Inleiding
Learn how to replace the motherboard on your Sony H.ear On 2 headphones!
This guide focuses on replacing the motherboard component located in the left ear cup. This guide will require soldering and desoldering. Please see Hoe moet je (de-)solderen? before you attempt to desolder and resolder necessary on the components. Although optional, it is recommended you remove the battery before operating on the device for safety reasons.
Wat je nodig hebt
Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
