Inleiding
The Bluetooth Transceiver, also called the NFC chip is a small green chip that manages bluetooth capabilities. It is located in the left ear cup and requires soldering and desoldering to replace.
Wat je nodig hebt
Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
Then, turn the ear cup over and carefully lift the plastic cover off to reveal the internal components of the right ear cup.
