Ga door naar hoofdinhoud
Sony FDL-220R Watchman Speaker Replacement
Wat je nodig hebt
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: stap 1, afbeelding 1 van 2 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: stap 1, afbeelding 2 van 2
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: stap 2, afbeelding 1 van 2 Sony FDL-220R Watchman Speaker Replacement, Remove screws: stap 2, afbeelding 2 van 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: stap 3, afbeelding 1 van 2 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: stap 3, afbeelding 2 van 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: stap 4, afbeelding 1 van 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: stap 4, afbeelding 2 van 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: stap 4, afbeelding 3 van 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: stap 5, afbeelding 1 van 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: stap 5, afbeelding 2 van 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: stap 5, afbeelding 3 van 3
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sam Putnam
484 Reputatie
4 handleidingen geschreven
Baylor, Team 4-5, Williams Fall 2014 Lid van Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 287
