Ga door naar hoofdinhoud
Sony FDL-220R Watchman Button Replacement
Wat je nodig hebt
    1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: stap 1, afbeelding 1 van 2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: stap 1, afbeelding 2 van 2
      • Press down on the textured area and push towards the bottom of the device.
      • Gently remove the battery cover.
      • Remove the three AA batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony FDL-220R Watchman Button Replacement, Remove screws: stap 2, afbeelding 1 van 2 Sony FDL-220R Watchman Button Replacement, Remove screws: stap 2, afbeelding 2 van 2
      • Locate the five 5x11mm screws surrounding the battery compartment.
      • Remove screws with a Philips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony FDL-220R Watchman Button Replacement, Remove back casing: stap 3, afbeelding 1 van 2 Sony FDL-220R Watchman Button Replacement, Remove back casing: stap 3, afbeelding 2 van 2
      • Grasp the entire back half of the Watchman's casing.
      • Snap off the casing from the bottom of the device.
      • Gently pull off entire back casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: stap 4, afbeelding 1 van 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: stap 4, afbeelding 2 van 3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: stap 4, afbeelding 3 van 3
      • Carefully grasp the entire circuit board.
      • Pull the circuit board off of the device's plastic casing.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: stap 5, afbeelding 1 van 2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: stap 5, afbeelding 2 van 2
      • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
      • Buttons/switches should be simply resting in their slots on the device.
      • Remove all three buttons/switches.
      • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
      • If one of the buttons/switches is broken, simply replace it with a new one.
      • When replacing, make sure that the slot on the switches faces up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Sam Putnam
484 Reputatie
4 handleidingen geschreven
Baylor, Team 4-5, Williams Fall 2014 Lid van Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 22
Altijd: 562
