Ga door naar hoofdinhoud
Sony FDL-220R Watchman Antenna Replacement
Wat je nodig hebt
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: stap 1, afbeelding 1 van 2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: stap 1, afbeelding 2 van 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: stap 2, afbeelding 1 van 2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: stap 2, afbeelding 2 van 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: stap 3, afbeelding 1 van 2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: stap 3, afbeelding 2 van 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: stap 4, afbeelding 1 van 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: stap 4, afbeelding 2 van 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: stap 4, afbeelding 3 van 3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Conclusie
Sam Putnam
484 Reputatie
4 handleidingen geschreven
Baylor, Team 4-5, Williams Fall 2014 Lid van Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 496
